- Jan 24, 2020
- 72
- Plaster
First off, a big thank you to this forum. It was the APP that introduced me to TFP, ashamed to say, initially to find out what sort of website would charge a subscription for such a basic app. As I dug deeper, I realise there are such great people here, and the advice put the pool shops to shame. I support paying for the app, knowing it will fund TFP. Whilst it was too late to save the $400 I spent trying to battle an algae problem, I know the tips here will save me hundreds more.
So my question: I'm on my 6th day of SLAM and my pool has gone from opaque to crystal clear. It also passes the overnight test. However, each morning, I still see a carpet of brown dead algae. My robot vacuum cannot hoover it up, it just swirls it around. It makes the floor clean, but I'm assuming it's just dissolved. Backwashing still shows lots of white stuff (algae). So strictly speaking, I pass all the criteria to end SLAM.
The pool water is 30 degrees (37.5F), and I have bush fire debris to contend with. The air temperature is 35-40 ( 95-104F). Daily CL consumption is high (maybe 6PPM) but since I didn't know what I was doing before, I cannot say if this is normal. So I wonder for this summer season, can I lower the CL levels and just contend with the fact that algae will grow because of high temperatures and ash and I should expect higher than normal CL consumption?
Current stats:
Pool Temp: 28c (37.5F)
PH 7.2 (6 days ago before SLAM)
TA: 60
CH 400
CYA: 50
SALT: 5300
CSI: -0.69
LSI: -0.34
TDS: 3800
Phosphates (before SLAM): 3.7
Waterco Eco Filter, DE added, SWG turned off, Filter running 6 days straight.
Current stats:
TA: 60
CH 400
CYA: 50
SALT: 5300
CSI: -0.69
LSI: -0.34
TDS: 3800
