Boost pump making god aweful sound
Oct 17, 2011
51
Denton, TX
Rebuilt my boost pump because the ceramic seal had cracked and it was leaking.
I got the new impeller, and seals.
I had removed that tiny little rubber gasket that goes around the axel for lack of a better term.
At the shop I said, I need that little one for the rod that turns the impeller.
Guy at the shop said you don't need that it really doesn't do anything
1. Is that true?
2. Could not having that be why my boost pump is making a horrible loud high pitched whining noise?
Kinda sounds like metal on metal.
It is so loud I really can't use the pump because it will irritate neighbors.
