Results 1 to 7 of 7
Thread: About to take the Borax plunge!
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    OK, before I do this are there any final suggestions? I've read the sticky article over and over again and I'm ready! (I think)
    How soon can I add the second half of the borax / acid dosing?
    - 25K Gallons, Jandy AquaPure Model Pure1400 SWG w/ AquaLink RS PDA, Jandy LXi Heater Model 400
    - Jandy CV460 Cartridge Filters
    - IG Plaster Pool w/ rock waterfall & weeping walls, Elevated spill-over spa
    - 2 X Jandy Stealth SHPM2.5 pumps (one for pool, one for waterfall), Pool Pump ~ 100 GPM in pool mode
    - UltraPure UPP25 Ozone Generator, Polaris 280 w/ Polaris Halcyon booster pump
    Guest
    Re: About to take the Borax plunge!
    Quote Originally Posted by TroyB
    Right after the first half. It's really a lot easier to do than it reads.
    Apr 2008
    Central Texas
    326
    When I did mine I just made sure that the pump was running to circulate everything, then waited about 30 minutes between major doses of chemicals.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Guest
    If you brush the pool in between the first half and second half like I outlined in step 5 of the how-to
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    it should take you about that long so you can just add the second half after you finish brushing.
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    If the creek don't rise, I'll do it on Sunday.
    Apr 2008
    Central Texas
    326
    I forgot about the brushing part. I did that also. I have the fabulous Wall Whale brush that REALLY stirs up the water as you brush (and does a much better job of brushing, as it applies plenty of pressure on the brush).
    Polaris 280
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    Well I couldn't wait. I just finished. 15 boxes and 4 gallons of acid. Not hard but a bit labor intensive.
