Thread: Adding muriatic acid w/o pump running
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    As the subject suggests, is it unwise to add small quantities of muriatic acid (one pint to one quart) to my pool w/o the pump running? Would it be OK to let it sit overnight until the pump starts the next morning?
    - 25K Gallons, Jandy AquaPure Model Pure1400 SWG w/ AquaLink RS PDA, Jandy LXi Heater Model 400
    - Jandy CV460 Cartridge Filters
    - IG Plaster Pool w/ rock waterfall & weeping walls, Elevated spill-over spa
    - 2 X Jandy Stealth SHPM2.5 pumps (one for pool, one for waterfall), Pool Pump ~ 100 GPM in pool mode
    - UltraPure UPP25 Ozone Generator, Polaris 280 w/ Polaris Halcyon booster pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding muriatic acid w/o pump running
    If you have some way of manually circulating the water, such as using a pool with a brush or net at the end you can use for stirring the water in the area where you pour, then that's better than nothing. However, it really is better to pour slowly over a return flow with the pump running. Muriatic Acid is VERY strong so until it gets diluted it can cause damage. Now that said, it would be far worse to pour in the acid without the pump running in a vinyl pool since vinyl is particularly sensitive to low pH. A plaster pool such as yours will be heartier in that regard.
    Do you not have a way to manually turn on your pump temporarily?
    Richard
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    Quote Originally Posted by chem geek
    Richard
    Yes, I normally run the pump for 30 minutes to an hour but was just wondering if I could skip this step. Is 30 minutes to an hour long enough?
    Yes, muriatic acid mixes in very quickly as long as there is some circulation. An hour is sure to plenty, and 30 minute is probably enough.
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    When I add acid, I turn pumps on high to get a good circulation going and then add. I let run for about 20-25 minutes.
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
