Results 1 to 12 of 12
Thread: Pool Cleaner Gets Stuck Under Ladder
    Riles_J's Avatar
    Nashville, TN
    218
    I recently received one of the 4-wheel suction pool cleaners for Christmas it seems to do a good job cleaning our pool. However, the ladder in the shallow end is just high enough (12-15" or so) to allow the cleaner to wedge itself under the ladder and get stuck. My ideas where to either somehow attach a 'U' shaped section of PVC to the bottom of the stairs to prevent it from getting under or maybe hanging something off the bottom rail of the stair. Does anyone have any ideas on how to prevent this?
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Pool Cleaner Gets Stuck Under Ladder
    Hey Riles !!
    What kind of cleaner is it. We have the same trouble with ours getting caught under our stairs as well (Wedding Cake style) ! During opening this year I am planning on going to Lowes or Home Depot and getting a clear piece of plastic about 6" wide or so ( I measured once in the fall when the steps came out and forgot the numbers ) ..... but anyway I am planning on attaching it to the front of the steps at the base with stainless screws in hopes this will solve the trouble. We have the "Zippy" pool cleaner and I actually like it a lot. We used to have the Polaris and was a piece of junk !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Riles_J's Avatar
    Nashville, TN
    218
    I have the 4-wheel thepoolcleaner. I don't have wedding cake steps but just a standard inground pool ladder like this one
    http://discountpooldepot.stores.yahoo.n ... nline.html
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    The K12330 for Letro cleaners, or the G-21 Ladder Guard set from Zodiac (Polaris) will work on your steps. Hayward also makes a ladder guard.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Riles_J's Avatar
    Nashville, TN
    218
    Perfect, thanks! Is one ladder guard better than another?
    riles
    they are all pretty good, i like to use the ones from polaris
    thanks
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    What can you use to go between the handrail and the lowest step (concrete step) to stop it from wrapping around the hand rail? It would have to go between the vertical wall of the step and the vertical portion of the handrail. The handrail is one of those round, stainless types.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    budster's Avatar
    Dec 2008
    272
    Quote Originally Posted by fofa
    Nothing comes to mind, but you might adjust the "butt jet" on the Polaris towards the "up" position to keep it from climbing on the step. Also, push the head float a little more forward towards the mast, too.
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    Guess I'll have to keep the pail full of bricks between the handrail and the step for now huh?
    budster's Avatar
    Dec 2008
    272
    Yes, unless you adjust the cleaner not to climb, as I noted above.
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    Climbing is not an issue, the handrail enters the floor of the pool about 12 inches (give or take) from the base of the bottom step, the cleaner has a tendency to wrap it's hose around it, so I have to block it from going between the handrail and the step.
    budster's Avatar
    Dec 2008
    272
    I understand now. Many of the deck-to-pool rails end on the bottom step, so I was suggesting not letting it climb on that step. In your case, that is apparently not relevant. I don't know how your configuration, can you post a pic? Depending on where your cleaner's wall fitting is, and where the handrail is, you might be able to shorten the hose. Once again, a pic would really help.
