I have an Aqua Rite Electronic Chlorine Generator and it is not generating any chlorine. The Turbo Cell is 1 year old and test good at the local pool shop. The Control Panel reads Power "ON" and "Generating". The salt level is 3400 per control panel and pool store. The PH, ALK and Stablizer are within limits. Still no chlorine.
I've pulled the PCB and it has some heat/burn marks at the base of the Current Limiter (Digi Key 570-1062-ND).
There is only two parts to the system, the cell and the control panel. Should I replace the Current Limiter or just go with a complete new PCB? The poll store said the only other possibility is that there are phosphates in the water but it is clear (using shock and chlorine tables in skimmer) and there is no real source of phosphates near the pool.
I've had the system for over 10 years without any issues until last year the cell went bad.
Suggestions.
Lar
Suggestions.
Lar
