I am wondering if anyone can help. I need to replace the flow sensor on my salt water generator. I have a Nature2 Fusion Soft 1400. I closed the pool drain and skimmers, because I thought that this would stop the water from flowing out of the Nature2. When I unscrewed the connector for the flow sensor, water started leaking out. When I removed the sensor entirely, it started draining with pretty strong force. I was able to quickly reconnect it. I don't know if this is water draining from the pool, or if it is just the filter emptying. I have a Jandy Cartridge Filter (CV460). This is what everything looks like. The valve positions are how they are normally set (without closing pool drain, etc). Is there anything that I can do to slow the water? How should I position the valves? Is this likely coming from the pool or the filter? I appreciate any input!
Additional Photos:
IMG_0454-2 | Flickr - Photo Sharing!
IMG_0452-2 | Flickr - Photo Sharing!
Additional Photos:
