This year i upgraded to the intex 18ft x 52 in ultra frame. So i made my hole bigger leveled it out and got her going. Its running on the intex sand 2400 gph sand filter and 15000 gallon salt water generator atm. However, my hayward skimmer is on the way. When it gets here ill put my waterway 1hp with 100lb sand filter on it and hard plum everything. Question should i leave the standard skimmer port w/o floating skimmer and the hayward skimmer so i have two inlets? I plan on adding a fountain as well. Ill post pictures soon.
Water numbers
FC 4
Ph 7.6
TA 85
CYA 35 (still have the sock hanging trying to get the 4lbs of cya dissolved) Goal is 65-70
Salt 3200 ppm
BBB user since 2009
Thanks
Germando
Water numbers
FC 4
Ph 7.6
TA 85
Salt 3200 ppm
BBB user since 2009
Thanks
Germando
