Thread: BBB Method when you are gone
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I have not switched over to the BBB method yet but I am planning to after I finish reading and completely understand it. My new home has a 12,000 gallon (aprox) pool and it has a Rainbow Lifeguard Chlorine feeder. With the using bleach for chlorine how often are you adding it during swimming season? I don't mind adding it daily if necessary but what do you do when you are away for a week or so?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Guest
    Re: BBB Method when you are gone
    When you are gone for a week or two you use your chlorinator (once you have gotten your CYA into proper range). You could also have someone you trust come over and put bleach or liquid chlorine in the pool for you every day or two. You should have a good idea of how much bleach you need once you get into BBB so they just need to pour it in.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by waterbear
    So it would be OK when using the BBB method to have a couple of tablets in the feeder and just have it turned down all the way until you leave, or pull out the tablets and add only when you are leaving?
    Thanks
    Polaris 280 robot
    Pool Calc user
    Guest
    Since the tablets always add CYA I would not put them in until you need them.
