I'm not an expert using Bromine. I just know a couple other people that used it. They didn't do a very good job of using it though. I think they thought it was lower maintenance then it really was. Anyway, they both ended up switching to Chlorine. The guys on this board are experts, so they'll help you use Bromine the correct way. I'm sure you won't have the issues my friends had. However, I would like to give you my experience with using Chlorine.
After a bit of a learning curve, I now have my tub running pretty effecient. On a fresh fill, I can get my water perfectly balanced in a day. For the first week or so, I use Dichlor to sanitize the tub. I add it every two to three days, and/or after each use. After that initial week or so, I switch to bleach.
On an ongoing basis, when I'm not using the tub, I check FC and add bleach every few days. However, my Tub will last 5-6 days with FC starting at 6 ppm and ending at 1 ppm if I don't touch it. If I shock to 12 ppm FC, it will last a week and still have 1 ppm FC. If I'm using the tub, I add bleach after each use. If I have a high bather load, I shock with bleach (and sometimes MPS) afterward. I check pH once a week, and rarely need to adjust it with acid. My pH has been stable at 7.8 for over a month. The only thing I add to my tub on a regular basis is bleach, and sometimes MPS.
I find this method to be very low maintenance, especially since I never have water problems. My water is always fresh, clean and ready to use, up until the time to refill. Also, the fact that I add very little chemicals to my water I can go longer between refills. I'm quite happy with this method, and don't believe I would switch to another one, unless it was just as effective, and I could go double the time in between checking the tub. i.e. two weeks.
As I said I'm not an expert on using Bromine, so I can't really compare the two methods. However, this is question for someone that is. I know Bromine is claimed to be a lower maintenance than Chlorine, because you don't have to add anything to the tub after each use etc. The floater keeps adding the Bromine. Then every week or so you shock to reactivate the Bromine. Correct me if I'm wrong on that. My question is this. What's the longest "reasonable" time you can leave a Bromine spa without touching it, (i.e. vacation etc.) and still have safe water? This is something I often wonder about. I welcome input from any Bromine experts.
