Thread: First Winter with 3 month old pool
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Have a few questions and not sure exactly which forum to put them in:
    1) My pool is salt water, the pumps are set to come on when the temp outside gets to freezing. With the pool being salt, does this change the temperature that the pumps should come on at? Specifically, should the pumps come on at a lower temp?
    2) Have a solar cover on the pool. One of the blue bubble wrap type ones. Do I need to do anything out of the normal during winter? Have had lots of leaves blowing onto the cover and a few making their way into the water. Is it OK to just pull cover off once a week and let my cleaner run a few hours to take care of debris? Can I go 2 or 3 weeks if there are leaves in the water at the bottom of the pool?
    Thanks all.
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: First Winter with 3 month old pool
    Where are you located/how cold are your winters? Mine is set at 37º which is what I was told is acceptable in my area. Here in Texas it is really only cold at night so many people here switch their filter cycle to night time to save on your electric bill. If it is going to come on at night anyway for the frees protection just let it filter then and be off during the day. I have not switched mine yet but am thinking about it. Does anyone else run filtering at night?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by Tonedeaf
    This is an interesting question. I'd bet the effect on freezing point due to the salt concentration has got to be less than, say, your altitude or some other consideration. I wouldn't change any settings because of it, but I am interested to see what the math on it is.
    I wouldn't leave leaves and nuts and things on your gunite for more than a week at a time. They'll stain eventually and you'll just create more work for yourself. Otherwise, leave the cover on as usual.
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Quote Originally Posted by AV8TOR
    I am in the Dallas Area. Like you said, it is really only cold at night unless we get a big cold front come through or an ice storm etc.
    I could switch the cycle to be on during the night, my waterfall comes on when it gets to freezing. Not a huge deal, but does add water on top of the solar cover, once it turns off, the water just goes back into the pool.
    My Pool Build
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Tonedeaf,
    I am in El Paso, this will be my 3rd winter, and my first winter without leaving my solar cover on, the reasoning is, by leaving the solar cover on in the past, I would have to replace it every 12-14 months, at $100.00 a pop I was getting anoyed, so this winter I have cleaned, dried and rolled up my cover and put it in the garage, when your cover in on, clorine, acid and the elements takes it toll on the cover, and winter time, I don't really care if my water is 60 degrees or 48 degrees, I only have one tree in the backyard, so the mess wasn't that bad, now the leaves are off, and the pool doesn't get that dirty, I have swithched my pump to run from 2 am to 6 am, and once a week I drop my polarias ATV to clean up the sand.
    IMO I feel leaving the cover on during the winter does not justify the cost of replacement so soon.
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    revstriker's Avatar
    Apr 2008
    Texas
    117
    In the Dallas area as well. Once swimming season is over, I normally remove the solar cover and store it in the garage. I'll pull it out again in March. It's just easier to do any needed maintenance without the cover. I have my freeze protector set at 37 degrees. I normally run the pump in the morning, but running it at night is probably a good idea. I also keep my navigator running full time. Helps to get the leaves and stuff that gets blown into the pool.
    I don't think the water getting on top of your cover is an issue, even if it freezes. Where you don't want the water freezing is in your pipes. Not sure if this would damage the cover though.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
