Thread: leak around clamp band
    rogerbrks's Avatar
    Round Rock, TX
    172
    My Polaris Halcyon booster pump has been very loud lately. Neighbors walk by the house and get so concern that they tell me my pump is running dry. I went to look at it and decided to start opening it and realize I didn't have a manual for it now it leaks around the clamp band. Is there a way to re-seal it? If so, what do I use? How is the best way to make the clamp tight enough to stop leaking?
    Thanks for all input.
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: leak around clamp band
    The squealing may be the result of a leaky pump seal. Are you sure the water you're seeing isn't just dripping down to the clamp from behind?
    You can lubricate the housing o-ring with some o-ring friendly silicone or teflon lubricant. If you notice your hands getting black in the process, or cracks in the o-ring, go ahead and replace it. In a pinch you could use a silicone sealant to force the issue.
    But take a close look at that pump seal.
    rogerbrks's Avatar
    Round Rock, TX
    172
    Thanks for the reply. I applied some silicon and the leak stopped. I'll have someone come out and see why it's so loud.
