Sand Filter Leaking
off2theocean
12
North Carolina
Hi,
I have noticed that my sand filter is leaking from under the multiport and under the band where it connects to the tank. It is only leaking on one side. Is there an easy fix for this? It is a not really a leak - more like a slow seep. I haven't noticed any pressure changes. There is also no water leaking out of the backwash hose so I think the multiport is fine.
The PB changed the sand in the filter after the replaster. I don't know if that had anything to do with it.
To be honest, a small weap like that would not bother me and I would just let it go. Sometimes the fix is worse than the problem.
To fix it you would take everything apart, and lube the o rings or replace them.
