Thread: Got my timer, but it may not work?
    Round Rock, TX
    529
    I just got the Intermatic 3-circuit 120/240v P1353 timer. Unfortionately, the documentation for it that I saw before buying it did not say it has three spst switches, not 3 dpst switched.
    Anyone know if it is ok to just switch one leg of the motor? That means I would be leaving on leg hot all the time. My existing switches are dpst, and I can't find a three circuit dpst switch anywhere.
    thanks,
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Round Rock, TX
    529
    After looking around I think I have a plan. As I cannot find a 3 circuit dpst timer anywhere I'm stuck with this timer.
    I don't like to just switch one side of a two pole motor because someone working on it may get a surprise they are not expecting when disconnecting the hot leg. So I'll run both legs through my existing dpst switch before the new timer. Then one leg will go to the pump hot, while the second is switched. This allows me to easily disconnect both legs for maintainance work. A little note inside the first switch should inform anyone else as to how it all works.
    This I think I'm comfortable with. Just thought I would update the thread in case some one else may be interested.
    dave
    That sounds like a plan. I would probably use a simple switch instead of your old timer, but if everything is already in place then why not.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Just a note. Get a switch rated for the current your system is going to draw.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Round Rock, TX
    529
    That was my thinking the switch in place is a big one and can handle the load.
    Another idea I had was to hook the new timer up to a single leg, then use it to switch three separate dpst relays. I can get the relays at the electrical supply house to handle the pump motors.
    Too many options
