Results 1 to 7 of 7
Thread: Stains - PH - FC Question
    Sep 2008
    Jacksonville, FL
    105
    So I have been reading a ton here on the boards this week and have come across many threads about stains. My pool has a few that I know of that appear to be in quarter size imperfections in the surface. I would guess that there are about 4-5 of them that wont brush out. Nothing major though.
    Well recently I had an algae breakout and shocked my pool. I ended up jacking the FC up to 40 which it is down to 22 now. My PH at the beginning of all of this was at 8.2 as well. Upon my reading, it looks like this had made me a prime candidate for stains. Is this true?
    Looking at the pool now I think there are slightly tinted streaks on the bottom. I am not sure if they are really there or have I just been reading too much about stains and now my mind is playing games with me. It is hard to tell since I do not get home until dark. I will look for sure this weekend. The finish on our pool makes it difficult to tell as well since it has misc. blue dots in the marcite. Not sure what they call this finish either. Anyway, it is mostly white.
    Any thoughts or suggestions here? Also, does anyone know what they call this finish just so I know for future reference?
    Thanks guys!!!
    16,500 Gallon Plaster, Pentair WhisperFlo WF-26 1 1/2 HP Up-Rated Pump, Pentair Clean n Clear 150 Cartridge Filter, BioGuard Mineral Springs MS-10 SWG, Hayward Navigator Cleaner, TF-100 Test Kit, Apollo Magnetic Stirrer
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Stains - PH - FC Question
    Could you post some pics? 8)
    You're done SLAMing when:
    High PH can cause a variety of problems, including causing metal stains and calcium scaling, either of which might possibly be what you are seeing. High FC levels also tend to encourage metal staining.
    Here is something that you can try to narrow down the possibilities. Find a spot/stain that you can see consistently and hold a vitamin C tablet against it for 30 seconds and see if anything changes. If the spot/stain goes away it is probably an iron stain.
    Sep 2008
    Jacksonville, FL
    105
    Thanks Jason... I will give that a try this weekend an post my results from it. I will also try to take some pictures of the pool so you all might be able to tell me if I am just seeing things or if there is something there. LOL
    Jason... by chance do you know what the name for that finish is? It is 99% white with some wide spread misc. blue dots in it, but not a ton. Maybe just a few every inch or so. LOL
    Sep 2008
    Jacksonville, FL
    105
    Here is a picture that I found on the intenret that looks pretty close to my pool. I don't think I have quite as many speckles though. Possibly Diamond Brite?
    It could be one of the quartz/plaster finishes, like Daimond Brite and Marquis, or it might be Beadcrete, or even Pebble Sheen. It is difficult to tell without a close up photo.
    In any case you treat it as a plaster finish. Whatever is producing the color is set in plaster.
    Sep 2008
    Jacksonville, FL
    105
    OK... So I was finally able to see my pool in daylight (geezz I hate daylight savings time... LOL).
    Here are a couple of pictures of the stains I was referring to. It is hard to see them but maybe it is just my computer. Also, these stains are very light and not drastic by any means... I just want them gone. LOL
    Hard to see but there is a slight brownish streak.
    These stains are right where the wall meets the step.
    Also, where the wall meets the strep. (Side Note... What is that goldish colored stuff building up on my return? I also noticed this all over my Haywood Navigator but it wiped off the Navigator with a towel.)
    Also, as you can see by the picture above and the ones below, this is the finish on my pool. Any idea?
    Thanks guys!!!
