Water from Balance Tank to Pool.
Balance Tank? I am not sure what you mean. Can you take and share a picture of what you mean.
Kim
Hi kimkats.
Thanks for your reply, but have worked it out. We have a separate balance tank which holds about 10 tons of water. we get the water delivered into the balance tank, which then supply's the pool. Then when the pool is on overflow it draws water from the tank. Also we put all the chems in there as well. Then we just have to keep our eye on the levels in the balance tank. Don't know about all you guys, but our pump room has no drain and in the winter we can get a lot of rain here. I have heard stories about the pool guys running around when the rain is really heavy and having to pump the rain water out of the pump room. So looks as if that's a job before the winter sets in. Should be fun.
Cheers.
Bill.
