Thread: recomend chlorine
    Oct 2008
    LONG ISLAND NY
    10
    recomend chlorine
    hello
    can anyone recomend a brand of chlorine to use when trying to eliminate and shock the algae from my pool. i always used what the local pool store sold me which is Dichlor. i am told this isnt what you want to use.
    thanks tom
    7,000 GALLON ABOVE GROUND
    CARTRIGE FILTER
    1 1/2 HP PUMP
    Guest
    Re: recomend chlorine
    For shocking and killing algae you want to use an UNSTABILIZED chlorine. Your choices are sodium hypochlorite AKA liquid chlorine(same as laundry bleach), calcium hypochlorite (what is normally sold as 'shock'), or lithium hypochlorite. Most of us here in the forum use liquid chlorine or laundry bleach. Shocking with a STABILIZED chlorine is not a good idea (except perhaps when using granular trichlor to treat black algae--not the recommended first course of treatment but useful in certain rare situations). IMHO, dichlor should NEVER be used for shocking since it will lead to over stabilization very quickly and this will, in turn, contribute to MORE algae breakouts!
    You might want to take some time to read the pool school section of the forum since the info you are looking for is in there!
    category/pool-school/types_chlorine_pool
    category/pool-school/defeating_algae
    I would recommend starting at the beginning and going through the whole pool school twice. Then you will have a better grasp of things and will probably have the answers you seek. if not then post a question!
