Thread: Stains and Absorbic acid test
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    Here is the low down.
    Had our pool renovated in 2001 when we moved into the house. It was a swamp, unused for years.
    Started getting little stains in it after a few years. I figured it was leaching through the back of the plaster.
    Hurrican Ike comes along, much sandy dirt from the greenbelt I live on. This sand has a slight red tinge to it, it's mostly a tan, but a slight red tinge to it.
    After power was restored (16 days) and i got the pool cleaned up, I realized the stains were much worse. And the stains were about the same design as the dirt that was on the pool bottom. So i figured maybe it was not leaching through the plaster, but just dirt, maybe iron.
    So I got the vitamin C (absorbic acid) tables, and placed on a really dark spot (but I figured some of those freckles were organic, not iron), but the staining did clean up (see the whiter circle around that split brown spot inside the red circle)
    You can see it has improved.
    Here is a picture of the middle of the pool.
    And the deep end
    I tried dropping some more tablets in parts of these areas, and they seem to have lightened them also.
    So for a 30K gallon pool, what do I have to do to remove these stains?
    Where do I get Absorbic Acid the quantity i would require?
    Thanks all.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Stains and Absorbic acid test
    Quote Originally Posted by fofa
    Welcome to the forum!
    Here's a link to MBar's (Marie) Ascorbic Acid Treatment: ascorbic-treatment-to-rid-pool-of-metal-stains-t2298.html
    She has two links near the end for locations to purchase AA.
    Good luck and please let us know how it goes!
    You're done SLAMing when:
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    Since I have a SWG, is there any special sequestering agent I should use?
    Thanks
    Guest
    ANY phosphonate based sequesterant should be fine. I like Proteam's Metal Magic or Jack's Magic pink stuff for iron staining. Purple Stuff is fine to use also, as it the Blue Stuff!
