Ok. I'm going to let the CYA dissolve a bit and see where I'm at. If it's too high I'll take the pucks out and stock up on bleach.
This is not exactly true. The higher CYA level should in fact let the SWG work less hard because less FC would be lost to the sun. The danger of the higher CYA level would be if you developed a problem and had to SLAM the pool.TFP recommends 70-90ppm. I keep mine at 70ppm. 90ppm means a higher FC which means, ultimately, running your SWCG harder. Anything over 100ppm is asking for trouble. I worked on a pool with a 150ppm CYA level and the SWCG just could not produce enough FC to stay within the TFP Recommended levels. The pool eventually went cloudy when the warm weather hit and I had to do a partial drain to get the CYA down.
This is why I'm not too worried, I think.This is not exactly true. The higher CYA level should in fact let the SWG work less hard because less FC would be lost to the sun. The danger of the higher CYA level would be if you developed a problem and had to SLAM the pool.
For the pool with 150ppm CYA, likely there was stuff growing the in the pool when the FC was not started high enough ... and thus the SWG could not compete with the growing organics. IF the pool started out "sterile" the SWG should have been able to keep up.
Although given the public nature of the pool, that adds a lot of variables.
Done, let me know if I got everything in there and THANK YOUPlease add your pool details to your signature as described HERE as it will help us help you.
If you just poured it in your skimmer I would be willing to bet there is a bunch in the filter dissolving.I'm not sure if there's a bunch of CYA that hasn't dissolved yet though. Does is dissolve pretty quickly since I didn't use the sock method?
So if it's testing at 50ppm now, would it be a good idea to backwash to try and buffer any further change?If you just poured it in your skimmer I would be willing to bet there is a bunch in the filter dissolving.
I'm assuming you mean fill water? I haven't tested it yet, but we are on a well that has some pretty nasty water. Very hard/metallic. We didn't fill the pool with too much of that though, had municipal water trucked in.Does your full water have calcium in it? If so, you could probably just leave the CH alone a let it come up on its own. Did the builder require a specific number? You're at the low end of the TFPC Recommended level.
Your TA will come down naturally as you regularly add acid to keep the pH in check. If the full water has high TA, then you might need to be a bit more aggressive about reducing it.
