Thread: New pool owner in Jacksonville, FL with cracked Pool
    Hello everyone!
    My wife and I are new pool owners in the Jacksonville area. We believe that our in-ground pool has a crack in it and are wondering how to go about fixing it? The crack runs from the coping to the floor on the shallow end of the pool. Looking for any and all advice.
    V/R
    Pierceab
    Dec 2007
    Central New York
    504
    Re: New pool owner in Jacksonville, FL with cracked Pool
    Can you give us more infromation about the pool?
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Butterfly's Avatar
    South Carolina
    10,045
    Hi PierceAB and welcome to the forum.
    As Hotrod asked, more info on the pool is needed. If you could post some pix that would be great, too!
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Is this a new pool or is it just new to you?
    Are you losing water?
    How wide is the crack? Less than a millimeter or is it wide enough to stick a finger into?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by 257WbyMag
    This is getting personal.
    Another question is how much do you want to spend? If you like a cheap fix and it's an older pool I'd probably start with some two-part epoxy like this: http://www.azpartsmaster.com/Product...y__PP0317.aspx
    Then see if it continues to grow. You might also consider drilling a small, shallow hole through the plaster at the end of the crack to try to stop it.
    There's always the chance that this is a larger structural concern but this would be a good start.
