Salt pool algae issue
Jun 8, 2013
46
13000 salt pool
pentair equipment filters automation salt
TF test kit
PH 7.5
CYA 50
ALK 95
Salt 3650
Calcium 225
FC 4.5 -5.0
CC 1-2
Phosphates 0
algae around stairs, under waterfall, and walls in patches.
I recently put in a new salt cell. Chlorine is rising without adding anything. I have been adding stabilizer powder but it seems a whole bucket barely moved it up.
I have shock bags (55% chlorine) not sure if i can/should use these or if liquid is favored due to salt and they might have stabilizer in them.
You need to get one of the Recommended Test Kits and stop letting the pool store test your water. They are really bad, especially at the CYA.
Since you see algae, you need to follow the ShockLevelAndMAINTAIN Process. And that is done without the SWG.
55% powdered chlorine is cal-hypo which will add calcium to your pool, which you do not need in a vinyl pool.
Wait, signature says K-1005, post say TF-100, results appear to be from a pool store :scratch:
why do you say they came from a pool store? i wrote them down as we did them from the kit with the magnetic mixer.
My pool is in ground concrete also. but will try the slam.
I have a waterfall fixture that the company used metal lathe that may be pretty much sitting in the water all the time. Not sure what part metal in the water plays but it probably can't be good.
Well, TA should be a multiple of 10ppm, the FC and CC numbers should not be a range, and you reported a phosphate number (which the TF-100 does not test for).
Ah, looks like you have a mystery signature from a software glitch. I will delete it and then you can please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
Pool School - Chlorine / CYA Chart
SWG Pools
says "not recommended" when stabilizer is at 60. Mine is at 50 and that is not on the chart. Can you explain that? Do I need to raise it first or subtract 4.
but then read this
SLAMing an outdoor pool is most effective when CYA is around 30 to 40.
I can slam and use 20 as a Shock FC with a 50 CYA?
Can I use those shock packets or is the calcium bad for my concrete pool also?
thanks!
Until you pass the SLAM and start using the SWG, use the non-SWG chart. In fact, the shock level is the same in both charts.
You should certainly SLAM with your CYA where it is and then raise it after you have passed the 3 criteria to stop.
Your CH is a little low, so you could use some of the cal-hypo, although be careful and sometime it can cloud the water and make you think you need to keep SLAMing. Be sure to lower the pH before you start.
update.
I put in the 3 bags of dichlor by accident. Stabilizer did not go up really from 60. also added 3 gallons of 8% bleach trying to get to the 25 + shock level. Ran the pump basically on high for most of the time.
tested it the next day and it was still low so I went to buy cholorine and had the water tested there. They said add 2 cups of acid and 2 cups of phosfree as my count was around 200. stabilizer 60
I have seen this pool, in less than a week, go from FC 30 to now 12 (rained last night) stabilizer is 60. It seems to be dropping very rapidly. Is this level of drop correct? i have bypassed the cholorinator the whole time so its not adding any.
The water is clear but concerned about the cholorine dropping so fast each day.
Thanks
Forget the pool store test and recommendations, unless you want to waste money.
Follow the SLAM until you pass the 3 criteria. A week is a long time so yes the FC can drop from 30 to 12 ... that would likely happen in 2 days.
i just did the instore test to compare mine with theirs. So I thought i had to shock it until it did not drop less than 1ppm over night. i am seeing like 4ppm loss in a night. does that mean i need to reshock again?
