If you want to replace water to lower the CYA first, that is fine. But a CYA of 70ppm is not horrendously high and certainly manageable.
You are going to need to add a LOT more than 96oz ... you can add it all at once using the methods described in Recommended Pool Chemicals. And yes, wait at least 30 minutes to test after adding any chemicals.
