cloudy blue pool
Welcome to TFP!
Your pool is cloudy because algae is growing in it. Algae is growing in it because there is not enough chlorine. Chlorine must be maintained above the minimum level for your CYA level at all times or algae will grow. Chlorine CYA Chart
Get a good test kit from the Test Kit Comparison, I use the TF100 from tftestkits.net.
Once you get your test kit you will need to SLAM Your Pool to kill the algae.
Here are some intro Pool School articles to read while you wait for your test kit
TFPC for Beginners
ABC's of Pool Water Chemistry
Here are the Recommended Levels for your pool.
Here are the Recommended Pool Chemicals and how to add them.
Use PoolMath to figure out how much to add.
Your welcome. Post your numbers once you have a recommended test kit and we can get you rolling. I love my TF 100 and you get more bang for your buck with bigger bottles. I recommend the XL option and the speed stir too.
That cannot cause cloudy water. Cloudy water is almost always caused by chlorine levels being too low for the CYA level. It is also usually a sign of algae.
