Thread: Leaves in skimmer
    Sep 2007
    Athens, GA
    2
    Leaves in skimmer
    During the final weeks of the season I find myself emptying leaves from the skimmer hourly trying to keep the water circulating properly (esp important with a chlorine generator). This becomes a bigger problem when I must be away from home for a day or two. I don't want to cover the pool this early in the fall... the weather is so beautiful and even though the water is too cold to swim, I really enjoy sitting outside next to the water. So I decided to try to rig something to keep the leaves from getting in the skimmer basket. This way, I can quickly bag the leaves from the surface a couple of times a day and still enjoy the pool.
    I've enclosed (attached) a photo of a simple leaf guard I made and attached to my pool skimmer. I made it from a metal mesh screen which I know will quickly corrode. I am also concerned about metal getting into the pool water. But, as a proof of concept, it does what I need.
    Question for the group - is there a better way? Anyone know of a commercial product to do the same thing?
    Bill Marshall
    18x36 IG Vinyl SWG
    Apr 2008
    Central Texas
    326
    Re: Leaves in skimmer
    Perhaps making one from some of the plastic leaf guards for gutters would work?
    http://www.homedepot.com/webapp/wcs/sto ... ogId=10053
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Sep 2007
    Midwest
    330
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    Sep 2007
    Athens, GA
    2
    Thanks for your suggestions. Looks like there may be a market for a commercial version... something that wouldn't corrode, snap in/out easily, and not injure a swimmer who happens to bump into it. Maybe PoolSean will pass this on to his contacts.
    Bill Marshall
    18x36 IG Vinyl SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Hi rrwcm and welcome to the forum!
    My leaf guard is a 14x24 plastic grid that DH had stashed in the garage. He saves/recycles just about everything.
    I tied a nylon string to the top of the grid (put a paver on top of the string to hold it deckside) and tied a water filled bottle to the bottom to hold it in place. It lies flat against the pool wall covering the skimmer.
    It does a fantastic job of keeping the leaves under control, but it does look a bit tacky!
    ....and, DLSDO
    Perhaps we'll get some more ideas!
    Thanks for starting this thread
    You're done SLAMing when:
