Thread: pool cover- how many pillows do I need?
    I'm buying my 1st winter pool cover. I have it selected but the pillows and whatever are separate.
    I have a 16' x 32' rectangular in ground.
    How many pillows, anything else?, do I need to do this right?
    Thanks.
    ETexas 24,000 Vinyl lined IG cartridge filter:(
    Jul 2008
    Solon, Iowa
    170
    Re: pool cover- how many pillows do I need?
    I bought one that is 4.5X15 and it is plenty big for my 15X30 pool. Just make sure that you secure it with enough ropes to the grommets so it won't move around when the wind blows. Mine has one grommet at each end. I found that you need 3 lines to each grommet (one tied along the long axis of the pool, and the other two at +/- 90 degrees to the first) or the wind will move the pillow even with the cover on.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Mar 2007
    Coastalish 'down easter'
    4,160
    For IG pools you don't need the air pillow! If you want to put one in it won't hurt anything, but it's not required 8)
    Luv& Luk
    -Ted
    Air filled??? I think I'm even more ignorant than I thought I was. I was thinking of those things that lay on top of the liner filled, I thought, with water.
    Would somebody please tell me what I'm talking about???
    Mar 2007
    4,160
    AH you mean water tubes. For a 16 X 32 with no stairs or Roman ends you'd need 12 8' tubes or 10 10' tubes. Though you can get away with ~ 1' between the tubes, it's a better idea to lay them end to end (invariably 1 or more will break each year so having enough so that you can re position them to cover the gap is a good idea.
    I hope this helps - if you need a little more on this, just ask 8)
    EDIT-- if you have stairs that extend past the pool walls or Roman ends make sure the cover is large enough to cover them I've seen a LOT of pool owners buy a cover for a 16 X 32 pool but not take the stairs or longer ends into account so end up with aa cover that doesn't cover the entire pool
    Luv& Luk
    -Ted
    if you have stairs that extend past the pool walls or Roman ends make sure the cover is large enough to cover them I've seen a LOT of pool owners buy a cover for a 16 X 32 pool but not take the stairs or longer ends into account so end up with a cover that doesn't cover the stairs.
    You know, the pool does have stairs on the end and I can't remember if I included that or not.
    Thanks! I'll check it in the morning.
