Thread: Reversing Time Delay for Cell
    Aug 2008
    Honolulu
    429
    Where we live we have very, very soft water, although the pool does have iron inundated volcanic dust/dirt blown into it by trade winds. What would the optimal reversing time for the cell, 4, 8, or 16 hours? Was set at 4 but changed it to 8 hours.
    One note recently we lowered the power setting to 1 from 2, so it runs a little longer at a lower amperage.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Ft Lauderdale, Florida
    1,455
    Re: Reversing Time Delay for Cell
    Extending the reverse time will extend the cell life marginally.
    You should keep an eye on the cell for scaling over the next month. If it stays clean, you can leave it on 8 hrs.
    Factory setting is 4 hrs.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Aug 2008
    Honolulu
    429
    Poolsean,
    Once again thank you for the fast reply.
    I will keep an eye on it.
    Aloha
