11:30 am today and fc is 19!!! Wow.
Added DE -psi 13
Cya 28
PH 7.2
Ordered new multivalve
Added DE -psi 13
Cya 28
PH 7.2
1) OCL isn't really proportional to CC. A lot of pools have zero CC throughout the entire SLAM process and can't pass the OCLT.
Prime is not lost when switching multiport positions. It was already lost (apparently) due to pressure increase. Pump is fully primed after backwashing and returning to filter position. Can increased pressure cause pump to lose prime? By the way, how do you "close off a valve on the suction of the pump"?However, closing off a valve on the suction of the pump when switching positions on the multiport will prevent losing prime in the first place.
Her waste line is a long hose at ground level which is still full after backwash/rinse, so I suppose this would explain lack of air when I switch from backwash --> rinse --> filter....air can enter the filter through the waste port...
What in the world kind of filter was that person using??? That clarity was the result of 4 days of work?? Granted, I'm only stopping by the wowens' house once a day, so the clarifying process could be happening faster, but WOW! Those are some amazing pictures! Not hard to believe bleach did that, of course, but hard to believe the filter cleared the water that fast!!As for the change in color, a single large dose can turn a pool from away from green quickly depending on how much material there is in the pool and with no CYA in the water the reactions will go faster, though the chlorine will also get broken down from the sun faster as well. See this post (see here if that post link doesn't work) where a lot of algae coagulates and drops to the bottom after 10 minutes after a shock. Of course, one has to keep adding chlorine to maintain the high FC level or else any algae not killed can continue to grow.
She must have a pin hole air leak somewhere then. What I fail to understand even if what you have said is true is how an air leak that isn't significant enough to prevent the pump from priming to begin with would be significant enough for the pump to lose prime. The only possible explanation I can imagine would be water level gradually getting lower in skimmer, causing pump to suck air with the water.Introducing air to the pump suction is the only thing that causes a pump to lose prime. Closing off a valve on the discharge won't cause it to lose prime.
