Thread: Question on PROpride Ultra Germicidal Bleach
    Is PROpride Ultra Germicidal Bleach OK for pool use? The label says 6.0% Sodium Hypochlorite and 94.0% Other Ingredients. The EPA Reg. No. is 70271-13-13152. I bought some at Smart&Final before I had price-compared and found that it is no cheaper than Orchard Supply's pool chlorine. I would like to use it up (I have three 3-qt containers), but my wife will not approve unless it is OKd by at least two independent sources.
    I am fighting black algae in Northern California.
    My Pool:
    15K gal in-ground gunite, Hayward Cartridge Filter C1750 (120 sq ft), Polaris 380 Pool Sweep with aux. pump, six 4x10 Solar Industries solar heating panels (south facing), Hayward RS750 main pump w/ 0.75 hp AOSmith motor.
    Jun 2008
    Marana, AZ
    347
    Re: Question on PROpride Ultra Germicidal Bleach
    I looked it up on the 'net. Propride ultra germicidal bleach is actually the same as Pure Bright germicidal ultra bleach. It goes by many different names, depending on the distributer, including Target regular bleach. It seems to be just regular ol' 6% bleach, so it's good for a swimming pool. The only difference between it and liquid chlorine for pools is the percentage of chlorine. Tell your wife to rest easy; she won't feel like clothes in a washer or something using this.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Thanks. I also looked it up via google, found the EPA report specifying approved use for swimming pools. The first bottle has been dumped in!
    My Pool:
