Results 1 to 19 of 19
Thread: I've been challenged to a THROWDOWN ! ! !
    Jun 2008
    Central MD
    149
    More of a friendly competition really. But a guy I work with has set up a challenge between myself and another avid bbq'er at work. The guy doing all the talking doesn't even know how to grill ! ! ! But that's OK, I'm flattered he's spending the effort just because he wants to eat my food. And it's all in good fun.
    But the stakes are high- the loser has to eat a veggieburger.
    So give me your best WOW 'em techniques and recipes. Right now I'm torn between beef brisket and BBQ Pork. Plan on doing the ABT recipe I saw here and maybe the pig candy too.
    What else you guys got to save me from the TOFU?
    24' Round Doughboy AG.
    Usually filled with 3 kids, the wife, and occasionally the dog.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: I've been challenged to a THROWDOWN ! ! !
    Sounds like fun. What will you be cooking on, and what is more popular in MD, brisket or pulled pork?
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    If you really want to win, do the Pork using John Henrys Pecan Rub available at Barbeques Galore if you can find one. It was a secret ingredient (years ago) in winning a California State Championship by a friend of mine. Slow cook or smoked with this rub will be a big hit.
    DrDave
    http://plansbyjorde.tripod.com
    Necessity is the Mother of Invention
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Do ribs. Less time to cook, and a bigger wow factor.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Jun 2008
    Central MD
    149
    I think the other guy is doing ribs. Pulled pork is definitely big here- which is exactly why I think I'm leaning towards brisket. A little less common. And my co-workers have mostly already had several different versions of pulled pork.
    I'll be cooking on my trusty Chargriller with offset smokebox.
    SeanB's Avatar
    Mar 2007
    2,622
    Good strategy. If you read my first 2 posts in this thread, you'll see a really good rub recipe and the basics of smoking a brisket.
    let-s-talk-bar-b-que-t16.html?hilit=brisket
    TFP Founder
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    brisket is good. Don't rush it. We cook ours for about 12-16 hours then it sits for up to 3 hours foiled in a cooler. (then we make burnt ends, MMMM) holler if you need any help!
    How about chicken?
    Take a bunch of chicken and boil it on the stove in water that has Old Bay in it (more is better !).
    After the chicken is cooked and drained, coat it in BBQ sauce and throw it on the grill just long enough for the BBQ sauce to cook.
    That's my secret recipe for Maryland style BBQ chicken.
    In-Ground. White Marbelite plaster. 21'-7" x 38' Figure Eightish Custom diving pool with 9' deep end. 24,750 Gallons. Pentair Challenger 2 hp pump, Pentair Clean and Clear Plus CCP420 Cartridge Filter, Paramount PCC-2000 In Floor Cleaning system with Debris Canister. Pool/House was a foreclosure that sat dormant for at least 2 years, and was an actual swamp. Using BBB and POP I made it a sparkling backyard oasis. I have a TF100 kit, and I know how to use it (mostly!). This is my FIRST REAL pool, but thanks to TFP, I know what I'm doing! (mostly!).
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    The problem with that is the BBQ sauce does a number on the grill and you still have boiled chicken.
    DrDave
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    boiling and BBQ should never be in the same sentence.
    West Michigan
    108
    Bobby Flay always does some fruit or veggies on the grill with the meat. Grilled pineapples etc. to have with your wonderful brisket. Let us know how it goes, I hope you smoke 'em! Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Butterfly's Avatar
    South Carolina
    10,045
    wmshay6 ,Good luck with the Throwdown!
    Hey Molson, how do you do 'burnt ends'? 8)
    Quote Originally Posted by Molson
    What about crock pot? :P
    You're done SLAMing when:
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quote Originally Posted by Butterfly
    Crock pot isn't BBQ... heh
    Burnt ends:
    When the brisket is done, before foiling to rest, cut off the tip (its the fatty part, as opposed to the flat)
    Cube up the tip and place in a foil pan, coat in sauce, you can sprinkle some rub on at this point if you wish). place back in smoker for 45-60 mins at 250. stirring occasionally to prevent burning. When tenderness and sauce viscosity is to your liking, remove and enjoy!!
    you can see the burnt ends beside the slices in this pic:
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    Pretty fancy TV dinners. Only foam not foil.
    Just kidding, looks delicious.
    DrDave
    critterdoc's Avatar
    Oct 2008
    30.0217 -090.2403
    23
    Quote Originally Posted by wmshay6
    ...The guy doing all the talking doesn't even know how to grill ! ! ! But that's OK, I'm flattered he's spending the effort just because he wants to eat my food. And it's all in good fun.
    God help you if you lose, wmshay! With those apocalyptic stakes hanging over my head, I wouldn't waste my time blindsiding him - I'd go nuclear and SNOOK the sucker with an CFB bomb.
    [youtube:2sd4ztsn]ZfbTO0GlONU[/youtube:2sd4ztsn]
    20K gal gunite, plaster in poor condition post Katrina
    1.0 or 1.5 hp primary pump
    Polaris 280 and Polaris pump
    Her name is: Free To Good Home :wave:
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    We tried the chicken fried bacon at the TX state fair this year. My husband put BBQ sauce on it. He thought it was good- but then he's a real "red neck". I thought it tasted like salty fat fried in salty fat- kinda weird.
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Jun 2008
    Central MD
    149
    Thanks for all the advice everyone. My Hickory smoked brisket took first place!!! I got a second first place for the pig candy- thanks Molson!! I had some folks that normally keep Kosher eating BACON with that one!!!
    I escaped the veggie burger for this time . . . .But folks are already gunning for me for next year!!
    SeanB's Avatar
    Mar 2007
    2,622
    Congrats! That gives you a full year to prepare and hone your skills. Try bacon wrapped quail bites with a slice of jalepeno and a wedge of your favorite cheese.
    TFP Founder
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thats awesome!! Congrats! the great thing about having time until the next event, is practicing is just as fun and you can eat your mistakes!
