Skimmer crack
Mar 21, 2015
12
USA
Ok so I have not even had this pool for a year, ordered it summer of 2014 and I just took the cover off my pool to notice that the skinmer is cracked.
I know I closed my pool correctly last winter and lowered the water level to the reccomended amount but now I have a question, should I order a new skimmer or epoxy the old one?
Here is a picture of the crack
Now I took a rubber mallet and gently tapped on the crack to try to close it and here is my result.
Am I ok to apply epoxy or something to patch the crack or do I have to order a new skimmer?
The reason why I am asking is because I heard that if the skimmer isn't installed right, it might screw up the liner.
If you're looking at the skimmer from inside the pool, you will unscrew the screws on the faceplate. Once the screws are removed, it will come right off. Replace the butterfly gasket and put the New box on. It helps to have someone on outside holding it so you can work inside.
