Thanks pooldv and Lisa!! That makes me feel much better. My clean running pressure is around 6... 25% would be every time it goes up to 7/8. LOL
So today was interesting.
Woke up to FC at 8 again, CC was 1.5. Brought it up to 14. Switched the pump to filter checking it every hour for air. It was looking so good.
Tested every hour all day, keeping it right around 14. Checked my CYA since it's been about a week since adding. It's hanging out around 33. (Going to check again in a few days.)
I've been the using leaf net/rake thing, and vacuuming with the intex / water hose vacuum. My actual pool vacuum won't work at the moment til the new pool parts come in. So I decided today to vacuum with a knee high inside the bag. What happened was so gross. Almost threw up in the pool! LOL I found where my chlorine is going! 4 knee highs FULL of gross slime. The first one was so full it was exploding out the top when I finally realized what was going on. I guess it had just been going through the bigger holes of the other bag. It was so GROSS!!!!! All in a very small area of the pool too. (Like 3x3 ft max)
So in the middle of the crazy slime mess. We had to run to get more knee highs to keep vacuuming. I decided to test the water one more time before we left. It was back to 7 (at least I think.) After the store we finished vacuuming and I was going to test again before going inside because it had been around 45 minutes. All I can figure is that either I added bleach and so did my mom, or I tested with 5ml instead of 10 by accident. When I tested before going in I had 10ml and was at 35 drops and dumped it out because I knew there was no way that could be true. So I washed with pool water and tried again. Finishing this time with 49 drops!!!!!! (FC 24.5) Still not sure how it happened, a few hours later FC had already dropped to 19. Hopefully this once won't hurt. Maybe it'll do some good killing off what is now a green swamp again.
It was dark, but its clearly all gross again!
