Percentage of DE after backwash??
May 26, 2007
185
Hi All,
I'm just going to backwash my filter unitl I can do a through cleaning for the end of the season in about a month. My unit calls for 4.8lbs of DE but I recall if backwashing it should be less. I thought it was 80%. Can anyone confirm?
Joe
Joe, as long as you wait until the filter's pressure gauge is ~ 8 - 10 psi higher than clean before you do a thorough backwash (multiple 'backwash/ rinse' cycles until the backwash water comes out ~ clean), you'll only get ~ 80% of the DE out, so only add ~ 3.75 - 4 lbs. If you backwash when the pressure only rises 2 -3 lbs, add the full amount 8)
Here is the 'use and care for de filters' post for you or anyone else who needs it.
Hope all goes well and you can get some more good use out of the pool before you close it and really clean the filter :wink:
