Thread: polyquat?
    Aug 2008
    MN
    19
    polyquat?
    Just ordered some 60% Algaecideolymer from poolcenter.com. Is this the same as the "polyquat" everyone is talking about? I want to close my pool soon and use the BBB method instead of the winterizing kit I used last fall. (although I did open to clean water-not green or anything!) I have purchased the bleach from Walmart and my new solid cover and algaecide is coming.
    27' 17,000 gal. above ground.
    Pentair Meteor sand filter-22", uses 150lb of sand.
    Pentair Dynamo 1.5 hp pump
    new water cycler that uses prefilled pacs of chlorine
    ~BBB method
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: polyquat?
    The MSDS for this product is here and yes, this is PolyQuat 60 that is talked about on this forum.
    Aug 2008
    MN
    19
    Re: polyquat?
    Thanks much!!
    ~BBB method
