Thread: Pool testing
    Pool testing
    How do I know if there is copper in my pool? Thanks!
    14,000 gallon in ground pebbletech pool
    Purex Clean & Clear Plus 2hp pump - Hayward Navigator
    Test Kit TF-100
    Cave Creek, Arizona
    Re: Pool testing
    There are a couple of ways you might find or figure that out. The best way is to get a copper test kit, prices and quality varies. Many pool stores will do copper testing, though the accuracy of pool store testing is highly variable. You can also try to guess at what might have been added to the pool that contained copper.
    Re: Pool testing
    I ask because I bought the TF-100 test kit and under the CH test section, it says to add R-0012 if your pool contains copper. I don't have any reason to suspect it does, but should I test it anyway?
    Test Kit TF-100
    Cave Creek, Arizona
    Re: Pool testing
    If you don't have any reason to suspect copper then assume that you don't have any.
    Re: Pool testing
    Thank you!
    Test Kit TF-100
    Cave Creek, Arizona
