IAqualink 1.0
boston62
489
Fort Myers, Florida
I have a schedule setup to run from 8 am to 1 pm everyday.
I have it setup up to maintain a temp of 85 deg, every 2 hours the pump kicks on to test the water temp, if cold heat pump
kicks on. What is happening is that when the heat pump reaches the temp it gos into the heat cool down then shuts off. I found the answer from Zodiac cant run that way..
