Thread: Main Drains
    Aug 2008
    Delaware
    45
    Main Drains
    After reading many posts about main drains,is there any harm in closing the main drains for any length of time ? Should they be left open most or all of the time?
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    Jul 2008
    Pittsburgh, PA
    118
    Re: Main Drains
    open them periodically so that the water within those lines doesnt go stagnant, but other than that you should have no problem as long as your water at the time you close them is balanced. Even if its not, pvc pipe is pretty resistent to low PH and the like. Just make sure that you still properly winterize them.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Aug 2008
    Delaware
    45
    Re: Main Drains
    Is there a benefit of keeping both main drains :P open at all times?
    Susi
    Aug 2008
    Delaware
    45
    Re: Main Drains
    Can it be harmful to leave the main drains open all the time?
    Susi
    Jul 2008
    144
    Re: Main Drains
    With a Polaris vacuum it is usually better to keep the main drains mostly or totally closed. The Polaris will take care of the bottom, and the skimmers will get better flow with the Main drains closed. Open them periodically to keep them clean.
