Spa leak
That is similar to the check valve mine uses. Only way to know is to compare the pic to what you have @ your equipment pad. best to look for branding as well...so you know 100% they match.
if you drain the spa into the pool, you can pull the valve guts and have a look-see at the seal.
looking through the site-glass top can you tell that the valve is closed?
My valve is just above the ground and easy to get to. I shouldn't have to drain the spa to change the valve, huh? Or is there more to this than I see?
Can't tell for sure that it is closed, but almost certain this was the culprit before.
Thanks.
