Waterbear,
Thank you for your reply.
Actually the difference, for my pool, is between 0.21 and 0.34 is 0.13. You might have been reading to quickly before you popped off your reply. This difference has been kindly rectified by JasonLion with his borate adjustment. I am not sure if the difference is logarithmic, if it is then it could be important, but as the error has been fixed this is a mute point and would therefore not have solicited my question.
As I at present cannot afford to send my water to be tested at a chemical laboratory. I will have to put my trust into the arms of Taylor test kits, as do many others.
I am trying to achieve and approximate CSI value of around -0.20, and difference 0.05 either side of that number would of course be acceptable, as my water fluctuates anywhere from 78 F to 86 F, with 82 F or 83 F being the norm.
This approximate figure of -0.20 seems, from all I have read, to be a good place to aim. The inaccuracy of tests is something we all sadly will have to live with. I think most of us who have been testing for a while know that, but your comments might help others who are unaware that they are not that accurate; although JasonLion with his correction to the "Pool Calculator" has rectified this CSI anomaly.
Aloha.
Aloha.
