Thread: hayward jets?
    hayward jets?
    i have an old '89 hottub and i would like to replace my jets. however my jets are hayward sp1438-c jets and i cannot find out anything about them. can someone help me find them or do i need to cut them out and replace them with a waterway jet? thanks.
    18' 52" deep laguna agp with pentair 1 1/2 hp pump and 22" filter, intex swg
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: hayward jets?
    According to my 2006 parts guide, they have discontinued the 1438 series but, as of then , you could still get the 'o-ring, spring and gasket kit', if any of those parts are the cause of the malfunction, they may well still be available (SPX1438FA).
    In what way are they not working? Hydro-Aire makes a very similar unit that we use on all our fiberglass stairs and benches - I can probably find you the part # if you'd like
    Let me know if you need any more info from me
    Luv& Luk
    -Ted
    Re: hayward jets?
    i dont know if they work or not. i was trying to find info if in case i need to replace them. i received a freebie and i am doing a restoration type. the person that gave me the tub said that it wouldnt work but he didnt know what the problem was. so i decided to updated the system, but was trying to find out if i needed to replace the jets, i could find them and order them if needed. it is an old '87 polyesian tub and found out the company bankrupted in '89.
    Alfred Beachport's Avatar
    Jul 2008
    Alameda, CA, USA
    36
    Re: hayward jets?
    Quote Originally Posted by mudrider420
    Hey, welcome to the world of spa restoration! In May I completed a restoration/rescue of an '80's spa, including rebuilding the pump and gas heater. All of 4 jets, and we LOVE it.
    So if you have any questions about the refurb, I may have an answer or two.
    In my case, I wound up replacing all the nozzles, the main drain, the skimmer, and one of the jet bodies because the plastic had gotten brittle after 20-odd years. The main drain was a good idea anyway because the newer model has better anti-entrapment protection.
    Please post photos!
    Cheers, Erik
    320 gallon Beachport San Clemente octagonal fiberglass spa, RayPak Versa 155B heater, Pentair Whisperflo WFE-4 1HP pump, Sta-Rite 100TX cartridge filter, Len Gordon FF1000 controller, Mariah blower
    Pristine Blue with 30ppm borax, bleach and MPS shock
    Re: hayward jets?
    i have decided to replace all 9 of my jets with waterway adjustable jets. i am also replacing everything else(main drain, plumbing, spa pack,motor, and heater). i also went and ripped up all the insulation off the shell, which was a good thing i did, cause i had a lot of mold and mildew under the insulation, which to me indicate either a leak or heavy considation(sp?). while i am waiting on my jets to arrive, i am trying to figure out a way to replace the insulation. any ideas on what kind i can use to help it stay warmer better?
