Thread: will muratic acid damage stainless pool lights?
    Oct 2007
    Central Texas
    104
    I was just about to add 1 gallon of muriatic acid for every 2500 gallons of water to perform an acid start-up of a pool. It just occurred to me that maybe I should remove the lights from the pool.
    Will this concentration of muriatic acid for 3 or 4 days damage the lights?
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Re: will muratic acid damage stainless pool lights?
    May not be a bad idea. I remember reading somewhere that it can damage them. I don't pour MA near them for that reason. Maybe someone else can offer more help.
    No Cover Charge
    17,000 gal IG w/ raised 8' spillover spa, 3M plaster, 10' stainless rain WF, Pentair SAM lights, Sta-Rite Sys3 cart. filter, Intellichlor SWG, 400kBTU Gas Heater, Paramount IF Cleaners, ET-8 Wireless Remote
    Oct 2007
    Central Texas
    104
    Most of the opinions I have received locally are that no damage will be done over the course of 3 - 5 days so I left them in. If it turns out I was wrong, I will amend this post with the information.
    Sep 2009
    Gulf Coast Florida
    13
    I know this post is old, but, yes it does ruin the faceplate of the light. It will turn it brown and will not come back to the original luster. Also, dillute acid in a bucket of water before tossing into the pool. do it at a rate of a 1/4 gal to 4 gals of water in a bucket
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist $600 w/part of deck included), 13,500 gallons, Intex SWG, solar panel
    My backyard is like a park... Why then does DH always want to go camping??? I just don't understand.
    Jun 2007
    New Jersey
    653
    But if you have garden hoses that have grown that impossible-to-remove black mold, chuck them in overnight. (I kept the brass fittings just above the water line, not sure if I needed to.). I discovered this by accident when the pool service crew left a small loop of hose hanging in the water when they were washing off the coping after pouring acid. I pulled it out the next day and it looked like new. Then I did the other 250' I had lying around.
    We did not dilute--we just dumped 3 5-gallon carboys of MA straight in: one at each of the long sides plus the deep end. No problems with a white plaster pool. We did pull the light and we put a cover pump in the deep end on top of the main drain running 24/7 to keep the acid distributed.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
