Results 1 to 12 of 12
Thread: Can a pool be physically upgraded?
    Aug 2008
    Bradenton, FL
    17
    The house we're buying has a simple pool. It's nice.
    However, due to my medical situation, a spa would REALLY fit the bill.
    Is it even possible to "upgrade" a pool to include additional plumbing, lighting and features like a Spa? I believe we could add the features without extending the pad the pool is on.
    I also want to add landscaping (all these changes are likely a few years off, but I need to start researching now so I can create a budget).
    I tried to search the forums for anyone detailing their upgrade story, but didn't find anything. If anyone has an upgrade story, I'd love to hear it!
    Be well all,
    Mack
    Be well all,
    Mack
    Mar 2007
    Knippa, Texas
    289
    Re: Can a pool be physically upgraded?
    How about adding a portable hot tub? I don't know for sure if your pool setup COULDN'T be upgraded, but I'm reasonably certain that it would be complicated and expensive. Portable hot tubs have more jets and are likely to be more comfortable than the inground kind. The plumbing is self-contained, so all you would need done is the electrical wiring. If there's enough space on your pool deck, you wouldn't even have the expense of preparing the surface for your hot tub. You would want to make sure your current surface would support the weight of the hot tub w/cracking, and that it's level.
    JMO. . . HTH!
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I agree, a stand alone hot tub would probably be better for your purposes. A spa attached to your pool is great (we love ours), but if you are looking for more therapeutic benefit, a stand alone is the way to go. There will be much better, more comfortable seating and LOTS more jets. You'd be able to do this at a fraction of the cost of adding a spa to your pool.
    The only way I would consider adding a spa would be if you were already doing a big remodel - new coping, plaster, deck, etc.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Aug 2008
    Bradenton, FL
    17
    good to know.
    Thanks. I figured it'd be a big deal.
    I like the idea of it being attached, but if a separate one is the way to go, perhaps we can integrate it with the existing pool with landscaping and whatnot.
    Thanks for the responses.
    Be well all,
    Mack
    Be well all,
    Mack
    Jul 2008
    Pittsburgh, PA
    118
    Portable hottubs are definatly the way to go. Check out hotsprings hot tubs, they are my favorite and are very good for people with arthritis. You can also buy them without siding and have a contractor make a surround for you, or you can buy them with a synthetic stone siding if you want. Very nice tubs. Just do us all a fovor and dont buy a thermo spa. Thoose are super expensive and horrible to service.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Aug 2008
    Bradenton, FL
    17
    I have to admit, when I read your suggestion, I was tempted to ignore it. I was afraid I was bein pitched. Glad I didn't. Of all the spa companies I looked at, Hot Springs seems to be what I would have chosen at first blush. And it wasn't close, btw.
    I'm not arthritic (well, except for a little in my back) and I'm young, turning 40 this year. What I do have is tremendous headaches every day that send tension straight down my spine. I've "retired" 5 massage therapists with the tension in my back. It's not the most rigid tension, but like a George Foreman punch, it sticks with ya. So the sync'd jet feature of the higher end Hot Springs Spas is a definite must have. Plus, I really like some of the cosmetic touches and the stone facade seems to be something that could be a designer starting point to add some pizazz to an otherwise plain setup in our pool area. Beautiful, but plain.
    Anyway, I just reviewed some pics of the pool area and there is a space just under the kitchen window that seems to be 72x72. So, unless there's a reason or requirement for a spa to be X feet from the house, I may just put it there. It would be under the cage but be distinct from the pool. Which I kinda like the idea of because now that I've had some time to think on it because if there is something wrong with the pool water (algae bloom, for example), the spa will be usable in the interim. I'll find out more over the coming months, but a separate spa is definitely what I'll do. The expense to amend a spa onto the pool and add a few lighting effects would be just silly, I'm finding out.
    Be well all,
    Mack
    I have a hot tub and there is nothing better at relieving tension. I used to go for a massage then to the chiropractor monthly due to the headaches and muscle tightness ( I fly quite alot and the airline seats are not good for the neck). Since I got the hot tub i go about once a year, They even called to see if I had moved!! Just make sure the spa can get to a good temperature.
    Sherra
    Kershaw County, South Carolina
    18x36 27,500 gal IG Vinyl Liner, sand filter, 1hp single speed pump running 6 hours twice per day, Hayward Swim Pure salt chlorinator, 2 skimmers, main drain, 3 returns, husband, 2 kids, 2 dogs
    Dec 2007
    Central New York
    504
    Let us know what you decided on and how it turned out.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Rocklin, Ca
    467
    I just completed my pool and decided to go with a standalone spa because they are much cheaper to operate, more comfortable and I don't have to wait for it to heat up.
    When calculating your budget don't forget about the electrical requirements. Although some smaller tubs can be run off of 110V, most spas require lots of power at 220V. The smaller 110V tubs typically don't have many jets and can not heat the water while running the jets. Mine required 60A/220V but 50A/220V are quite common. I did the electrical myself and material alone was about $600-700.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Aug 2008
    Bradenton, FL
    17
    @sattaker - yeah, my body is used to seeing a chiropractor 4 times a week, twice a day (I told ya it was bad). So I'm really starting to put saving for the spa VERY high on the list of upgrades. We save for everything (the house is the only thing we are doing on credit for obvious reasons), so it will be a while, but still.
    @cobra46 - I was already thinking about the power requirements. I know we'd have to drop another line, anyway, and since I'm no electrician (and too smart to be a Tim "the toolman" Taylor), I'll find a good electrician who won't expect me to put his kids through college for a simple drop and add to the box along with a run to the spa.
    @hotrod30 - well, I've decided on the spa. How it turns out will take longer than a vegasmom's pool build (sorry, vegasmom dear, I just read that and I can only say that living well is the best revenge. After all that, here's hoping you and hubby live REAL well!).
    Anyhoo, I like the Aria and the Vista (the V one, I forget the name). Size needed will be important. If there is a req that the pool be X feet from the house, that may change my choice.
    Be well all,
    Mack
    Be well all,
    Mack
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Every once in a while, someone with lots of extra cash will redo their pool completely, ripping out everything. My uncle is in the pool business, so sometimes, he gets his hands on some of that stuff. He called me about 2 months ago telling me he had a fairly new spill-over spa for nothing.
    I grabbed it, spoke to my pb, and he said it would be very simple to add on to the existing inground pool. The entire job took him around 8 hours and cost me about $2,000 for him to do.
    It is raised about 12 inches, but directly next to the corner of the pool. It looks amazing.
    It runs off of the same pump as the pool, and the jets work great.
    I then had to have my paving guy come do the pavers. The guy did an amazing job and charged me about $1,200 to pave the entire thing and make it appear seamless with the pool, including bull-nose coping around the spa.
    So all in all, it cost me $3,200. It wouldve cost another $3,000 if I had to purchase the spa itself.
    The spa is great, the jets are nice, and it looks amazing.
    But I have to agree with most others here. If you are doing this for health / therapy reasons, the stand alone / portable spas are better. They are more powerful, and they have MANY more jets.
    I love the idea of a spa being run off of the pool water, because all I do is turn the spill over on, and I get fresh / clean water into the spa. But as nice as it is, a "real" hot tub can not be beat in terms of heat and jets
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Has anyone ever thought of integrating a Stand-alone Spa into their pool? I don't think it would be THAT hard, but the pipin is kind of confusing. Basically, take the spa pump out of the spa and run piping for it over to the equip. pad and then have it set up so you can circulate pool water through the spa? Then you would have the benefits of the standalone spa with all the powerful jets, but the easier maintenance of a built-in spa.
    I drew a diagram of how you could plumb it... I'll post it if anyone's interested.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
