WOW its already hot here in Houston. My pool water was 90 degrees yesterday. I had to put the aerators on to help cool the water down a bit.
Getting that way here in the Dallas area. By the middle of the week I'm thinking the water will be pushing 90 too.
Hello summer!
7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
I'm about to start running the pump at night so the solar panels will cool the water. 90 is a little much!
What are aerators? Is this a feature that came with your pool?
I have been wondering how to cool a pool in the summer.
10,000 Gal. - Plaster – I.G. - Sand Filter – NOT USING MY Auto Puck Chlorinator.
Bpotter,
Refer to this thread. At the bottom of the page begins a discussion of a homemade aerator that duraleigh (Dave S.) installed in his pool that cools the pool using evaporation. There is also a link to a discussion on the poolforum that talks about it.
11,000 gal. gunite w/midnight blue and white pearl PebbleTec
Intelliflo 4x160 pump
Intellichlor IC-20 SWG
Pentair cartridge filter 420 sq. ft.
Mastertemp 400K BTU heater
Legend Platinum cleaner
Pool School
JasonLion's Pool Calculator
TF Test Kits
In my case they include 2 small returns just below the deck coping that have fittings that spray the return water up in the air in a fan pattern. I have a valve at the equip pad to adjust the flow and therefore the height of the sprays. My PB includes them on all their pools. They actually had several features that Im glad they used. Very happy with my PB.Originally Posted by Bpotter
It would be nice if mine would just get above 75.
to cold for me yet.
18x33 15700 Gal Oval Above Ground
Ranger Sand Filter w/Praher Multi Port Valve
A.O. Smith 1.5 hp Pump
Confer E9120 Steps
BBB And Sparkling Clean.
My pool is staying at a nice refreshing 82 degrees. I think it's because of all the returns in the inground cleaning system. My pool is a play pool and usually they warm up fast. My pool is always in full sun, too.
Buggs
14,000 gallon, in ground, plaster, free form, play pool.
Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
In floor Polaris cleaning system
Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
Southern Ontario - My pool was up to 89 yesterday thanks to my solar panels! More heat and sun for the remainder of the week - might bypass tonite - or I could have a hot tub on my hands!
