Well, budysr that sounds very familiar. We had a solar cover on 24/7, and I was misreading my CYA tube as well, so I was under chlorinating and not brushing regularly. I had started using a skimmer sock, and was catching a fair bit of yellow/green stuff in it, but thought I had the problem at a maintainable level- we live in the country- there is always something in the pool. Compared to the lakes around here, a little stuff on the bottom is nothing.
One day I pulled up the solar cover and the whole bottom of the pool was covered in a green poofy layer. The wild part is that the water above it was quite clear and we had been running the pump 12 hours a day.
We put the autovac to work, which of course stirred a bunch of it up, and the pool ended up greenish and cloudy. We had our first big fall cool front about that time, so I decided summer was over, and we put the solar cover away. The water temps dropped 10 degrees in 48 hours.
I started shocking at a higher level, vacuuming every couple of days and backwashing immediately after vacuuming. My sand filter seems to let the pollen gradually back into the pool over a couple of days, so I backwash immediately, regardless of the pressure reading. The vacuum really is picking up the stuff, because the water that comes out of the filter is bright yellow every time. Plus, the pollen level will reduce by about 1/3 with each vacuum/backwash cycle. Unfortunately, the way my skimmer is configured, I cannot leave the skimmer sock in while I vacuum.
I also brush while I vacuum, and then put the skimmer sock back in as soon as I pull the vacuum out- the next day, it is yellow/green with stuff, and I make a point of cleaning it out daily. I got a pack of 5, so I replace the dirty one with clean one and wash the dirty one with soap and water. BTW- they are just panty hose material with a wide enough opening to fit around the skimmer basket lip.
So I have been shocking, brushing, vacuuming, backwashing for about a week now, and the water is CRYSTAL, with just a little bit of yellow/white stuff on the bottom- like I said: country=stuff. It has not been this clear in a while- though it was usually reasonably clear when the "pollen" was sitting on the bottom.
And I had very little FC drop and never showed any CC's either- even when the whole bottom was green.
The takeaway from this for me-
1. Now I know how to read the CYA, I will do better with that. Here is the link that was given to me in another post about when the test is done: http://www.taylortechnologies.com/Chemi ... ntentID=44
2. My area has just too many contaminants to let me get away with the minimum FC for my CYA- I need about %20 more.
3. Brush more often (like every other day) and keep that skimmer sock in there, cleaning/changing daily during pollen season (which is 11 months of the year here). I may invest in a nicer skimmer sock- one that has a coating on it that helps trap more stuff: "Bioguard skim mor" http://www.poolgeek.com/BioGuard-Skim-Mor-P2243.aspx
One of them costs more than my pack of 5 el-cheapos, but if it helps, I'm willing. I know at least one person on this forum got one, and I will post to see how they are doing with it.
4. If I get can get a decent manual vacuum head (mine is junk), I will try vacuuming to waste when the stuff on the bottom starts to build up.
5. I started adding borates, and got up to around 10ppm (just guessing, I have not got test strips for borates yet), but when I removed my solar cover, my pH jumped big time. I will go back to working on adding borates gradually this winter with a goal of 50ppm. Hopefully, that will help prevent some of the surprise algae attacks.
6. My plan is to keep the pool open this winter, with just a leaf net for fall and spring tree drop (which is about to happen any day- I better get on it). Winter is only about 4 months here, and we have extremely high winds, so I am thinking a cover is a waste of time and effort. I will run the pump a little each day- I will keep the brushing up- any time I start to see an accumulation of stuff on the bottom. Also, reduce my CYA a little, as I got it too high without realizing. With the winter torrential rains that should not be hard.
7. I will not take off my solar cover when my neighbor is mowing his pasture- I should have known better-bad,bad,bad!
Hope that helps- I think my lesson here is that pollen happens, but not to get complacent, because algae follows if I let it.
