Thread: Autopilot tech ?
    Dec 2007
    NW Georgia
    56
    Autopilot tech ?
    I have had the board/card replaced by a authorized service rep 3 times in the past 2 mounths. I am now on the 4th board/card that I installed myself, service rep mailed board/card along with a new cable. This was installed yesterday. I purchased the Autopilot Digital with sc 60 cell software verison 4.2. The new board/card is an upgrade software verison 4.4. The question I have is
    1. When I powered the Autopilot on after installing the new board/card the display flashes on/off in an 3 to 5 sec cycles is this normal?
    I was able to setup the system just fine display does not flash when in setup mode.
    2. Also today when I got home from work I check the system there was no display I touched one of the display buttons and it came on is this normal?
    3. I am also unable to calibrate the salt level. When I try the display reads "not ready yet".
    4. I did talk with the service rep today and was told that the card maybe in Demo mode. So I disable this. I still can't calibrate the salt content.
    Any help with this would be great.
    Thanks
    41K L shape Vinyl IG, 2.0hp Jandy stealth pump, 300lb sand filter, Autopilot Dig-220 SC-60 cell, Dolphin Oasis Z5.
    Ft Lauderdale, Florida
    1,455
    Re: Autopilot tech ?
    The displays you're describing is correct for the version software.
    Regarding the salt calibration, please call the factory, 800- 786-7751 for support.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Dec 2007
    NW Georgia
    56
    As of this morning I am now able to calibrate the salt content. The unit was in Demo mode. The unit seems to be working properly. Thanks
    Rockcrawler's Avatar
    El Paso, Texas
    174
    What is the difference in Version 4.2 and 4.4, if your running version 4.2 should you upgrade to 4.4?
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    1,455
    Rockcrawler,
    Not worth getting the software changed. Here are the changes to the versions.
    1. Improved Menu Structure (similar to the Total Control)
    2. “View Setup” and additional information in “Test Pool Pilot”
    3. “Installer” menu includes “demo mode” as menu option
    4. Temperature Calibration added
    5. Languages include:
    a. English, French, Spanish and Italian
    6. After 20 minutes of no key activity or no errors / warnings, display reverts to a “walking dot” mode to improve life expectancy of the display. All other functions [pump, CL2 generation, timers, etc] continue in the background.
    El Paso, Texas
    174
    ok,
    thanks Sean,
