Results 1 to 14 of 14
Thread: Hurricane Questions
    May 2008
    Florida
    43
    Hurricane Questions
    So, with my friend "Gustav" on the way I thought this might be a great time to ask... is there anything specific I should do to or for my pool if we have to evacuate? I can't leave the filter/pump plugged in so I am worried about what I might come home to. And being it's getting to the end of swimming season, I'd like to be able to use it than to fight an algae bloom.
    Thanks in advance, as always,
    Alli~
    Intex vinyl 18' x 48 " AGP
    Learning the ropes so I can grow up and have my very own big kid pool! (IE -SUPER NOOB!)
    Dec 2007
    Central New York
    504
    Re: Hurricane Questions
    Never having that kind of rain that you will have, I will give a couple of suggestions.
    Bring the pool up to a good shock value. Let the pump run for awhile to mix it. Then I would turn off and bring the pump indoors to protect it from a flooded yard.
    I can't think of much more to do. You are going to have alot of wind, rain and stuff flying around.
    What ever you do, GOOD LUCK and STAY SAFE.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    I would add: put the cover on it before you go to try to keep as much debris out. Also might help keep the chlorine in just in case the sun is out!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2008
    Marana, AZ
    347
    You can also add some polyquat 60. Just make sure to follow the directions, and make sure you add it long enough before shutting the pump / filter off that it gets totally dissolved / mixed - I hear the stuff is thick.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Dec 2007
    Central New York
    504
    And now you have Hanna.
    Hotrod30
    Pentair VF3050 pump
    Mar 2007
    Texas
    444
    Quote Originally Posted by The Mermaid Queen
    I would be cautious with doing this. Where I live (Texas) it is always windy, and some days we have 40 mile winds regularly. And with 40 mile winds I have had the wind take the cover and bend the walls. So I would think long and hard before doing this. But this is JMO
    27' Round AG, 17,200 gallons, sand filter
    Jun 2008
    Marana, AZ
    347
    Quote Originally Posted by Poolidiot
    Good point. Intex is not known for its ability to withstand extreme conditions. I also saw a video in which a softside pool went through a hurricane, (ended up being close to the eye of the thing) and it ended up with minimal damage. It did not have a cover on.
    Hayward sand filter
    May 2008
    Florida
    43
    And now we have hannah...SHEESH! Could who ever is in charge of this cut a girl some slack!? lol
    Yeah I think I wont put the cover on because its not terribly thick. Im affraid something would hit it and rip it. I would rather fish out all the leaves and gunk...
    And what is Polyquat 60?
    THANKS SO MUCH for all the great advice!
    Alli
    Jun 2008
    Marana, AZ
    347
    Polyquat 60 is an algaecide. It's better than the copper stuff, because it doesn't add metals to your water, and it's better than most other algaecides because it doesn't foam.
    Hayward sand filter
    Dec 2007
    Central New York
    504
    Quote Originally Posted by Swimgirl
    And if you have to buy it at a Pool Estore, you'll wait forever. I ordered mine on Aug 17 and they charged my card Aug 18. I still don't have it.
    Hotrod30
    Pentair VF3050 pump
    Apr 2008
    Indiantown, FL
    58
    Where in Florida are you located? In 2004/2005 when we got hit by Charley, Frances, Jeanne and Wilma and lets not forget the two feet of rain we got from Fay. All we did to our pool was to bring it up to shock levels before the storm and then unpluged the pump to protect it from power surges. You will also want to have extra shock, salt, etc so that after the storm passing you can bring the pool back up to shock level. Remember that alot of pool stores will not be open after the storm because they will not have power. Also don't forget to remove your skimmer cover in Frances we forgot to take ours off and after the storm we found it a few hundred feet away. I hope this helps.
    Eddie
    Intex 16' X 32' X 52" 14,364 galllon AGP, 16" sand filter & SWG, Pool Rover & Sunrise Journey SPA 320 gallons, TechniChlor 110 SWG
    May 2008
    Florida
    43
    I'm close to Ft. Walton Beach. (near P-cola) Thanks for the great tips. Everything is out of the pool I am just thinking of water quality when we "recover" from the storms... I have stocked up on shock and chlorine but I might grab a few more bags of shock before the weekend.
    THANKS AGAIN! You guys ROCK!!
    West Michigan
    108
    Polyquat 60, here in Michigan@ Walmart is hth super Algae Stop is $16.(32 oz) no copper. Its the end of the season here for swimming. I'd leave the intex cover off too and ride without it. Good Luck with that storm and stay safe and dry. Let us know when you come out the other side...Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Nick's Avatar
    Jun 2008
    Bristol, UK
    36
    Good luck with the storm.
    Intex 16'x48" AGP 5,000 (uk) gallons
    Intex 635 pump
    Bio Diesel filter bags
    4 solar radiators and a solar cover
