Results 1 to 7 of 7
Thread: New Diamond Brite Plaster- When can I run Heater?
    I just had a total pool renovation- down to the shell. The Diamond Brite plaster was installed yesterday (8/26/2008). I was told that I cannot run my heater for two weeks. Is this just to be careful and are there exceptions? I am having my sons birthday party on 9-6 ( 11 days after plaster) and we are going to want to run the heater since it is getting to be cool here at night in the Philadelphia area.
    Thanks in advance- great forum!
    John
    18K gallon IG pool and separate 1200 Gallon IG spa - Both have: Diamond Brite Plaster- Hayward DE Filter -Propane heater- renovated 8/2008
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Re: New Diamond Brite Plaster- When can I run Heater?
    I have never heard that before, do you know why you can not run the heater?
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Quote Originally Posted by Rockcrawler
    I imagine they want to keep it from getting too hot and protect the plaster. I do not know but they have it in the instructions and I asked also- they said to wait two weeks. I need to use it after 11 days. Anyone have a comment on this??
    I spoke to Tech service at SGM who makes Diamond Brite and they said it is OK to heat the pool. His assurance to me was that if I heat the pool to 85 how can that be bad when pools in Florida are naturally that temp after a few days and do not have problems. The pool party is on!!
    Butterfly's Avatar
    South Carolina
    10,045
    Good news for you, John!
    We hope your son's birthday party will be great!
    ETA: Your pool is beautiful. 8)
    You're done SLAMing when:
    Thanks. Now I need to power wash concrete, replace deck and fence, landscape.....one thing always leads to another. Since the pool looks nice, now everything else looks old.
    Jul 2008
    Dallas, Texas
    27
    Just to expand on this, generally the reason they tell you not to run the heater is because they do an initial acid bath with a quartz plaster. However, they should have completely bypassed the heater if they were going to do that. The acid will corrode the heat exchanger.
    Brian
    30,000 Gallon Renovated Pool and Spa
    Flagstone Coping and Wall
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jandy Aqualink Control Center and Palm Remote
