Thread: Combined Chlorine
    Fayetteville, Arkansas
    220
    Combined Chlorine
    Would someone in the know post a little about CC levels or lack of. My tests are clear before I
    add the reagent, that is after I do the test for FC.
    What about them? I understand CC is where the strong chlorine smell would come from. If my FC is
    3.0 and my CC is 0 -- is that a good thing?
    Thanks - now, out to the oasis and a beverage !!
    20x40 30,000 gal IG Liner, Pentair II Sand
    Arizona
    925
    yes, it is a very good thing
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    New Jersey
    98
    Yes that is perfect....enjoy the water!
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Combined Chlorine
    Quote Originally Posted by Rangerman
    Here's a quote from a learned individual:
    "We measure chlorine in our test kits. Sometimes they test "chlorine". This is actually Total Chlorine--the TC you asked about. Our better test kits test for Free Chlorine (FC) which is the stuff that does all those good things. The better tests also test for Combined Chlorine or Combined Chloramines--CC. This is the used-up chlorine that smells like disinfectant and irritates eyes. Its presence means you are metaboliziing something."
    So, as the other folks have said, a CC reading of 0 is a very good thing.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
