Hello everybody. We are building a small plunge pool most in ground and the top 20" sticking above. This will be all tile. About 10x20 feet, 42" to 65" deep plus a tanning deck on an L which is 6x8 feet. I am using a local contractor here who has built dozen or so pools. The pools he has built are awesome but he is not super sophisticated on pool construction. He is basically a very good masonry contractor who has built a dozen pools. Looks like most were partially managed or designed by the pool owners. To me, it looks like he builds everything with overkill. He just completed a building here for us for commercial purposes and his quality and attention was very good. No problems though looks like he overkilled the esign of the walls on this building. (bond beams etc and floor thickness).
BUT, in Nicaragua, they build things from bricks and cement with the ease of a North American carpenter.
Will have a waterfall, 4 Jandy Deck jets and 2 Pentair Bubblers.
This will be a slab floor with re-bar in it. Then a perimeter bond beam connected to the slab that will also have re-bar going up into each block. At the top of the walls, another bond beam all the way around an then a wall cap/coping. All the re-bar connected.
He wants to use 8" on the pool floor.
I will likely have to provide moderate guidance to him. More on the pool systems side and some on the structural side.
A few questions to start...
1. Is this overkill?
2. Many threads on here suggest that full tile will seal itself using the correct quikset and grout? I am cloudy on that issue.
3. The tanning deck does not need footered to the bottom of the rest of the pool? The wall around it sticking out of the ground bond beamed at the top? (It is only like 20" tall at maximum)
4. I like the Intelliflo 3Hp but the complexity of the electronics make sme nervous as service here would be non-existent. (I will import my pump/filter and many other items). My other choice is the Whisperflo 2 speed 2Hp which seems a lot simpler. Both are close to the same price.
I am asking for comments.
Thanks!
Thanks!
