Results 1 to 8 of 8
Thread: Aqua Chem Vacuum Head-How to Hook it up????
    Good Morning all,
    I have just been through what we thought was going to be a little wet weather, and it has lasted 4 days. Yes I am talking about Typhoon--I mean Tropical Storm Fay. Today the weather is a little better and its not raining for once and I would like to go and vacuum my pool out using my new pump that I have received about amonth ago.
    I have a aqua chem vauum head(as seen below)
    [attachment=1:r7ydkvog]thumb_lg_vinyl_vac_head.jpg[/attachment:r7ydkvog]
    and I am trying to connect it using my new Intex 2500 Pump/filter.See below
    [attachment=0:r7ydkvog]56633E.gif[/attachment:r7ydkvog]
    Problem is i am having problems hooking it up. I dont know where to attach the other end of the hose. I have a connector that the vacuum came with but its not hooking up to my outtake that my water goes out.
    Is there anyone out and about in Pool Land that Can help me.
    Misty
    10k gal. IG vinyl, 1 hp pump, 200 lb sand filter, solar panels & cover
    Jun 2008
    Marana, AZ
    347
    Re: Aqua Chem Vacuum Head-How to Hook it up????
    That's a suction type vacuum, that hooks to your skimmer. What type skimmer do you have? A lot of pools have some sort of a way to hook up a vacuum hose to the skimmer; mine has a plate to put on top of the skimmer with an opening to put the vacuum hose in.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    This is what I am have on mine.
    [attachment=0:kmfxynj2]41ehwJEmtAL__SL500_AA280_.jpg[/attachment:kmfxynj2]
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    It's been a while since I had my Intex pool - doesn't the hose from the bottom of the skimmer route over to the suction port on the pool? IIRC, you have one port that returns water to the pool, and another port that sucks it to the pump. Didn't you have to use a special adapter for the skimmer, and if so, will your vac hose fit on it?
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Yesterday I tried to fit my vacuum hose over the adapter for the skimmer and its not large enough.
    The skimmer hose is I think 1/2 and my vacuum hose is a 1/4( its smaller then the skimmer hose)
    I never got a skimmer adapter.
    the hose and vacuum cost about 50.00 and I have never been able to use it.......
    Misty
    Jun 2008
    Marana, AZ
    347
    Do you mean 1 1/2 and 1 1/4?
    That's a common problem, btw. I had the same problem with mine. Home Depot and Lowes carry schedule 40 PVC fittings; you probably just need a reducer. That's how I fixed mine, a 1 1/2 inch to 1 1/4 inch reducer. You might be able to find that at a pool store, too. And they are cheap; you probably will spend < $2.00 on one.
    Hayward sand filter
    I am going to have to try that. I need something, this water vacuum that came with pool isnt cutting it.
    Thanks again.
    Misty
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    You could just do what we do. Remove the adapter on the inlet for the skimmer. Then just put the hose in the hole. The suction will keep the hose from coming out as long as you don't pull hard.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
