- May 30, 2012
- 1,584
- Plaster
- CircuPool Edge-40
I have 4 jets on my IG pool. Eyeball removes easily, just unscrew large "nut" holding it in. Do they make a 1.5" hose adapter that will screw onto the remaining male thread. I plan on adding a Solar Bear collector that I want to push water from the return to the panel and back into pool with another hose. I'd like it a quick change fitting so I can remove the hoses when pool is in use. Maybe something similar to how a pressure cleaner attaches (but with 1.5" hose). My plan is to have most piping hidden except the 2 hoses into the pool. Going to try solar before investing in a heat pump, so this is likely a temporary test.
